Fifth Injector
LucianCi
Hello.
I am new and have a 2.2 D-Cat.
I want to know what would happen if the fifth injector (from DPF) wet injection, i mean that's has leaked diesel???
The car seems to have triggered a problem too often the cleaning particulate filter (sometimes after 20 km,city driving) and then removing the dense smoke, start blue and gray-white finish.
What will be the problem???
DPF might be history. That particular engine is very choosy in oil. If you use anyother oil than EPS oil, it will destroy the DPF.
That symptom is usually a result of a broken DPF.
Thank's.
First, i had Castrol 5W30, but it was for engines without DPF, so i canged it with Mobil1 5W30 for engines with DPF. Tha last time i put Eneos 5W30 (first japan oil). I didn't heard about this oil, but a friend of mine told me about this oil ...
So, you believe that my DPF is broken ????? Howe can i test DPF ?????
I'm worried about. That simptoms is stronger when it's cold.
I apreciate.
Only way to test it is to go to a Toyota tester and see what the sensor says about the air coming out of the DPF.
If you engine has had anything elste than EPS oil, it's almost 99% sure that the DPF is hitory. Mobil has 5W-30 EPS oil and Toyota has 5W-30 EPS oil (it's Mobil oil but much cheaper than Mobil). Toyota has a statement that no other oil sshould be used on this engine type.
