Rear Windscreen Wiper
borodaz
hi, does anyone know where i can source one of these from ? apart from toyota, my girlfriends wiper has cracked at the point where it mounts onto the stud that turns to wipe the window.
she has MOT due next month so need to find one fairly quick and cheap as possible, thought you people were the best to ask :)
oh its a 51 reg
oh its a 51 reg
Don't know where to source one. However, I believe that a rear wiper is not a mandatory fitting on a car, so can't fail MOT if it is not working.
I think Wiper Blades are like lights, even if they are not mandatory, if fitted they must work.
If that is the case, you could remove the blade and arm for the MOT. You may have to cover the spindle if it protudes.
Failing that, a breakers yard may be (although not necessarily) cheaper than Toyota dealers
