Light Bulbs Behind Heater Switches
KenMavor
With the dark nights here now switching on the lights in the car is now with us at 4pm. Just noticed that a couple of the lights
behind the heater switches seemed to have gone. Would normally head to a scrappy but very rare to see an Avensis
there.
Anyone any idea where I can get them. It's a 2002 Avensis Verso. I'll get a photo of the central dash so you can see what I mean.
Ken
Buy them from Toyota, they look like little top hat's if i have my models correct. About a £1 each?. Change them all while your at it.
Regards, Beagh.
Regards, Beagh.
Have gone down the route of Toyota - £4.58 a pop - ouch!!! Only bought one and will see if I can match it from another supplier
at a much reduced price.
Ken
Regards, Beagh.
Ken
I changed mine few weeks ago,,at €4.50/each.There are 4(four) bulbs alltogether!!
Try any motor factors,they have them also,,but still expensive.
I must have my lines crossed, maybe we are talking about different bulbs here. I purchased 3 bulbs, part nu:T90011-11040 from Toyota for €6.80 inc VAT, i am in & out of parts department on a regular basis, so i get a bit of discount. bulbs look like tiny little Top-Hats?
Why don't you try Parts-King for price.
Regards, Beagh.
there.
Ken
Hi Ken,
Just noticed that two of the bulbs behind the heater switches on my '05 Avensis are gone.
Can you please advise me the best way to access them.
Thanks,
Paul
To replace bulbs, remove trim that runs from passenger door along top of glovebox & across top of radio with with cup holder at the end. Just gently pull away, starting at door side, assembly held in via plastic clips. Remove g/lever surround & you should be able to access 4 radio retaining bolts, radio/heater rotary switches come out as one unit. Slide switch pack to one side, all you need to do now is use a small electrical screw driver to dismantle rotary switch unit.
Regards, Beagh.
PS: Don't know about later MK11 models, but 03/04 do not have radio code.
there.
Ken
Hi Ken,
Thanks,
Paul
Paul,
Depends what model and type of Avensis you have. As Beagh noted that's the way to get into it. You will have to then disconnect the
heater unit and there should be some screws you will need to undo to separate the heater unti to get into the bulbs. Best way is to
take one of the duff bulbs out with it's holder. Usually a twist and pull job on the bulb socket. I found the bulbs were 12v 1.2w
and you can get them off Fleabay for a fraction of what Toyota charge. Check the bulbs but the should just pull straight out
with a bit of pressure and TLC.
Got mine from Electroquest123 on eBay and the key part was the bulb type was 286 - Box of 10 quality 286 Bulbs 12 volt 1.2 watt.
Let me know how you get on.
Ken
there.
Ken
Hi Ken,
Thanks,
Hi Beagh and Ken,
Many thanks for your reply and advise. I intend to replace the bulbs next weekend.
Paul
Paul
Paul,
Ken
  • 4 weeks later...
Hi
I have an '05 Avensis too. The bulb behind the heater is also gone. I have the bulbs already. I can remove the trim and take out the radio/heater unit.
Unfortunately, I get stuck after that.
Kind regards, Pat
Hi
Kind regards, Pat
Pat,
Lot depends which type of dash you have. There should be some "latches" holding the heater unit together which you have to
carefully unpick and then separate the heater into two parts. You should be able to disconnect the heater from the
wiring as well. Once you get the heater unit into two parts you should be able to take the bulb holders out and replace
with new bulbs.
Ken
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
