Rav4
igormus
Hi Guys
Ok to prevent abnormal noises in cold times - i ve treated all doors rubber seals by slilicon spray grease and disclosed that the rear door closing limiter (lower under the lock on the door as black truncated cone) is relieved and it looks like come to loose. I m in doubts whether it is normal or not. Please guide me what to do -- should i have it re-tighten or it is normal designed specially for self alignment?
Cheers/Igor
Hi Igor
Yes the little plastic insert inside the door stopper is loose;
door_keep.pdf
Hi Anchorman
Whether i ve could not explain it correctly? Look at the inner side of the rear door -- in order to safe a seal rubber from door kicking against it -- two plastic or compound parts (as cones) are installed both in the botom and upper sides and tthey service as thrusters. I was talking about both that are found as loose. Just have your rear door observed. THe PDF you sent is another part mounted on the body. I ve found that both are a bit loose on my door. Please come back
Cheers/Igor
