Jammed Cd With Error 3
shazm
Hi guys,
I have an '06 Avensis T-Spirt 2.0 . The cd player was playing fine then all of a sudden when I went to skip a track I got "error 1" displaying on the unit. When I tried to eject the cd I got "error 3". And that is what comes up every time I try to eject it since then. The radio works fine, tape player I assume works fine , but I never use it.
It might be that the unit is screwed and I gotta go on eBay and get a replacement as I have seen other people on this forum have done. But I would like to know whether there is a way to force the cd out?
Any suggestions appreciated.
Also recommended sellers on eBay and instructions on replacing the unit would be very handy too!
Thanks,
Shaz.
You could withdraw the unit and take the steel casing off carefully that will reveal the offending cd and then remove it, is it an original cd or a copy with a stick on label on it ? If so i had same problem and the adverse weather conditions had lifted the label from the disc once removed and sorted never had a problem once unit was replaced, never put a copied disc in again "lesson learnt" good luck.
Hi guys,
It might be that the unit is screwed and I gotta go on ebay and get a replacement as I have seen other people on this forum have done. But I would like to know whether there is a way to force the cd out?
Also recommended sellers on ebay and instructions on replacing the unit would be very handy too!
Thanks,
Shaz.
Hi shaz this will sound stupid but try disconnecting the Battery and then reconnect it the cd unit should eject the cd coz of the power loss. all toyota's have this function.
I haven't got a Mr T stereo so might be barking up the wrong tree.
Most CD players (well on PCs etc.) have a small hole on the front in to which a thick stiff wire can be inserted to press a manual release. Might not be on but if there is try CARDEFULLY inserting a straightened paper clip . If not I'm talking rubbish.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
