Toyota Celica Gt (6 Gen) Abs Light Reset
maksiuf
Dear All,
Does anybody can help and let me know how to reset ABS fault light as i have found and rectified a problem
I do not want to go to dealer straight away, as it is easy option
" How can i do this at home"
Cheers
Dear All,
Cheers
do not want to be rude, is it Toyota forum? I am sure someone knows how to do this?
To clear fault codes, leave the jumper in place between terminals Tc and E1 with the key on, then pump the brake pedal eight or more times in three seconds or less. When codes are erased, the ABS light should flash two times per second.
its pretty quiet in here at weekends , if you use the search feature you may have found what you wanted , if you look in here http://toyotaownersclub.com/forums/index.php?showtopic=65725 you will find all kinds of info from basic problems to celica facts n figures.
