Helpp Celica Gen 7 Only Revving Up 300 Rpm
jayjay7
HI GUYS GOT A PROBLEM ON MY HANDS IV GOT A CELICA GEN 7 WHICH HAS BEEN INVOLVED IN AN ACCIDENT BUT NOW IT ONLY REVS UP TO 3000 RPM LIKE ITS ON A LIMITER ANY IDEAS WHAT THE PROBLEM CAN BE....HELP GUYS NEED YOUR ADVISE
CHEERS
CHEERS
Is the mil light on?
CHEERS
hie whats the mil light if you mean engine management light yes it is mate
Best bet is to pull the error codes & start from there, either buy a OBD2 code reader (cheap ones £30 on ebay) or take it to a garage & have the fault codes read. What sort of/how heavy an accident has the car been in? It's possible something in the engine/drivetrain has been damaged & the ECU has gone into 'survival' mode & limited your revs to 3k. It maybe something as little as a knackered sensor or broken wire but you wont know until you read the fault codes.
ok so best thing is to do the fault code read and should know from there right ok il be doing that then hope its nothing major.well the accident was n/s not tha heavy on the front no were near engine.took off the whole corner so needed lights wishbone etc
