Electric Antennae
midengined
Year 2000 MR S. Have fitted new pole/drive belt to existing motor, but wont retract completely, leaving 2 inches outstanding. Original toothed drive belt snapped, has anyone done similar please?
Suggestions welcome, thanks. Midengine
PS pre-cats done on this car before I bought it 2 years ago, but not in time, complete new block etc etc. Anyone risking it, dont!! It is like new now though.
Hi and welcome to the club :thumbsup:
I don't know if this post will be of hellp to you CLICKY
Sorry to hear about the engine problem but it is a misconception that removing pre-cats will stop the early design engines from failing. CLICKY
Les
Les
Hello, Thanks for your interest, I have solved the non-retracting aerial as a result!
Re pre-cats, I know this is controversial. I can only say mine is "the other side" of the pre-cat issue. That is, engine failure over 2 years ago, new block, pistons etc etc pre cats removed, and 2 years further on, engine is as new. No oil consumption, maximum performance and mpg.
I am assured by a "specialist" engineer it wont recur now the cats are removed. Only time will tell?
many thanks again and best wishes
"Midengine"
