Toyota 2e 92 Model
neilct
can anybody please give me an advise with regards to my car's engine, the odometer reading is at 200k plus km, not yet overhauled but with newly replaced valve retaining clips, you see at first start (that is from cold start) a noise can be heard much like the diesel engine is sounding but eventually subsides as the engines gets hotter. do you recommend an overhaul? the engine's power is still there.
where can i buy good quality engine mounts mine located at the front center just slightly below the radiator is already worn out after 2 months of usage.
