Engine Light Code P0125
jako999
Hi all well the story so far the managment light came on and I replaced the top left lamda great that fixed it. I drove it around and after 5 mins the light came back on, I checked again and this time I have a code of P0125 which means insufficient coolant temperature for closed loop fuel control. Now the water temp is sitting a 89 degrees C. Does any one know what I could have done? Where is this sensor? Its a bit strange that both should fail at the same time?
I have reset the code several time but it come back after about 5 minutes.
Anyone who needs a lamba sensor you can get them from Euro car parts I payed £84 a lot better then Toyota's £170 and if you live in the Halesowen area I have a fault code reader.
Can we still drive it?
2002 2.0 petrol auto
Thanks in advance.
What made you think the Lamda sensor was faulty in the first place??:)
Hi the fault code said heater error so I metered it out and it was open circuit
