High Tickover From Cold
PDT
I have a 1.8 petrol Avensis. I am curious about the high tickover from cold. This morning was not particuarly cold (9 on in car temp display) but the engine was ticking over at 1900 RPM. This did reduce fairly rapidly to the normal 750 RPM.
I have noticed that the tickover was high first thing in the morning even during the summer, nowhere near the 1900 mark but still higher than normal. This was also happening when I started the car after work (6pm) when the car had been standing in the sun all day.
Is this normal or does it indicate a fault.
Thanks for any advice,
Pete
Pete
Quite normal Pete, are you old enough to remember 'chokes' on cars? They did the same, enrich the mixture when the engine is cold and increase the revs to prevent stalling. With fuel injection, it is done electronically and automatically, the temp sensor tells the engine management that the engine is cold so automatically enriches the fuel/air mixture and increases the rpm. As the engine warms up, the sensor passes the information to the EM system and gradually reduces the enrichment and rpm. The temp sensor is in the coolant system so it depends on the temperature of the coolant and not so much on the outside air temp.
There are earlier threads on the same issue from last winter if you want to search them out.
hope this helps.
Pete
hope this helps.
Thanks for the reply Q.S,
My first car (Morris Marina) had a manual choke, subsequent cars like Mk1
Pete
hope this helps.
My first car (Morris Marina) had a manual choke, subsequent cars like Cavalier and Nova had automatic chokes. But I don't remember any car reving quite so high. I also don't recall having to use the manual choke at the end of a hot summers day.
I may be a bit paranoid because the 3 year waranty ran out last month!
Pete
Hi Pete
No to be worry about -- that is more than OK and looks like standard.
Cheers/Igor
Pete
Hi Pete
Cheers/Igor
Thanks Igor. I've stopped worrying now.
Pete
