Not As Big As You Think
I was in the local Toyota dealers the other day and decided to have a look at the new Verso, have to say the updates didn't make me want to dash out and replace my existing car. However, whilst I was there I had a look at the new Prius and couldn't help noticing that the car seemed very long.
When I got home I had a check of the spec sheets and it seems the Prius is longer than a Verso. The car lengths (in mm) compare as below:
Gen III Prius 4460
New Verso 4440
Gen II Prius 4450
Old Verso 4370
Avensis 4695
So if you have a short garage and the choice of a Prius or Verso, the Verso will fit with up to 90mm less length.
Gen III Prius 4460
New Verso 4440
Gen II Prius 4450
Old Verso 4370
Avensis 4695
Yes - Verso is not a huge car unlike some normal saloons eg Rover 75 - my previous car was 4750mm, so I actually went to an MPV which was shorter but much more versatile ( due to the height ).
