Help Engine Noise
trevor8985
Can any one help? I am the owner of 2003 Toyota hiace with the 2.5 d4d engine witch has a rattling sound on light throttle low revs, then the sound weakens if more throttle is applied and again the sound comes back on lifting off but only for couple of seconds. I think its injector but not sure any help would be good.
It's not a problem as such.
The likely reason it they do it is due to the D4D two stage injector fire when cold, some do it some don't, maybe to do with ECU programming and self learn function.
I believe it is to do with meeting emission targets, maintaining smooth idle and ease of starting when cold.
People are getting concerned due to the rattle that is in most CRD engines when cold as some are louder then others, they are working in excess of 20,000psi injection pressure.
Remember they don't have any pre heating.
During the second phase of diesel combustion all the fuel that has accumulated and formed stoichiometric ratios during the delay period (1st phase) will suddenly ignite and burn explosively.
When the engine is cold or it is cold outside more unburned fuel will accumulate before the combustion temperature is reached resulting in a bigger BANG due to the increased delay period. This is the characteristic "cold knock" you will hear on a diesel on a cold morning.
If in doubt give Mr T a quick bell
Cor blimey, Guvnor :o He's all technical as well as a smart a........................lec :eek::laughing:
  • 1 year later...
thanks for reply. you say its cold knock but mine still does this when engine is hot. any help welcome
Sorry to did up an ancient thread but I've got the same issue. Did you find the cause?
  • 7 years later...
I too have the same problem with rattling nioince at certain speed in Hiace 2010 - when engine is between no load and beginning load......so to say!!
.........anyone got the reason figured out yet?
