Dice Interface For Ipod
OldRaver
I've just been given one of these to fit to my 04 XT3 D-4D. Does anyone have experience of fitting this product? I'd like to be able to mount my iPod out of sight if possible - this particular piece of kit also has an Aux input which I would like to be able to use eventually.
Any ideas/instructions regarding the fitting and location of all the bits would be much appreciated. I've looked at Anchormans excellent posting regarding this - but it's for a XT4 and everything looks a little different. Any official Toyota instructions anywhere out there for this mod? Thanks.
I'm not familiar with this kit but the instructions for taking the radio out are the same on yours as they are on mine. If you need to know about any other trim, let me know.
Thanks! Weather permitting I'm going to do the first bit (connections etc) tomorrow. I'l let you know how it goes.
Thanks for this Anchorman! Still raining very heavily here so will have to postpone this for a while. Thought I might try to route this set up to the cubby below the steering wheel - looks like the easiest place to access an iPod unless I get a mount for it.
  • 5 months later...
has anyone fitted one of these yet? i have one, but i cannot get it to work. i have tried all the dip switch combinations, but i get nothing at all?? any help would be appreciated. i have the 58827 head unit.
I asked a local stereo specialist to fit mine - he couldn't make it work and thought the 'black box' was at fault. I sent it back and was given a replacement without any fuss. Shortly after that my cam belt snapped and as some of you will know it took 3 months to get the car back!
Anyway the car is back now and the replacement Dice is sitting waiting to be installed and as soon as I get a chance I'll have a go at it my self.
The post that was placed by Anchorman(below) is really helpful and explains what to do in detail.
I'm just concerned now that as you have not managed to make your unit work it could be a compatibility issue. Where did you purchase your unit from? Could you get some advice from the seller?
  • 4 months later...
Any joy with fitting the ipod adapter to a 58827 unit?
I bought a DICE adaptor and it does not work on my 58827 headunit :-(
Cheers
Mathew
  • 7 months later...
Cheers
Mathew
hi did you ever manage to get your dice kit working as I have the same problem with a dice media bridge and a 58827 head unit?
