Gen 7 Wheel Stud Length
robs
Please can anyone help me I want to use a 14mm wheel spacer so need longer studs.
Not sure how long the standard ones are to order longer ones!
Anybody know the standard length fitted to a 2003 Toyota Celica vvti
Just fitting wheels with different offset so need spacers.
If you are buying the wheels new,then the manufacturer should have a listing for a wheel nut/bolt sets, having worked in the automotive accessory shops supplying such items.
It's not the Nuts that are the problem, robs has bought the wrong Rims and decided to substantially increase the track on his car which is not a good idea, but as always, each to their own.
The only safe way around this choice, is to fit Hubcentric Spacers which are rather expensive.
