Toyota Starlet 1998
cam19
Hi everyone, having some trouble with my toyota starlet. Seems to lose power, when accelerating for a long period of time. Noticed this the other day, when I was in the outside lane overtaking a bus, on a slight hill. As i was driving past, at 70mph, the car started to slow done, and although my foot was flat done on the accelerator, i could feel the engine struggling. I then pulled over, to discover smoke coming from the bonnet. The smoke appeared to be coming from the left hand side of the engine, near the Battery. I have no idea what this could be, coolant level appears to be fine, oil level is fine. (spark plugs have also been replaced) :huh: any suggestions would be appreciated
Cameron
Hi everyone, having some trouble with my toyota starlet. Seems to lose power, when accelerating for a long period of time. Noticed this the other day, when I was in the outside lane overtaking a bus, on a slight hill. As i was driving past, at 70mph, the car started to slow done, and although my foot was flat done on the accelerator, i could feel the engine struggling. I then pulled over, to discover smoke coming from the bonnet. The smoke appeared to be coming from the left hand side of the engine, near the battery. I have no idea what this could be, coolant level appears to be fine, oil level is fine. (spark plugs have also been replaced) :huh: any suggestions would be appreciated
Cameron
Ermmm.... that leaves 2 other area's for concern........
On the left is the gear box.... slowing down you say, has the gear box got oil in it ??? , smoke - may be this was clutch dust/fumes rising from a hot clutch ???
Obviously i cant see,............. when driving the car slowed, did the rev's increase ????
Did the smoke have an odour to it ??????????
Just some views my friend.
Thanks for the reply, I had a look under the car, to find that the gearbox might have a leak, as it oily. The revs remained the same, although there was a very strange odour coming out the bonnet, smelt like burning plastic. How easy is it to change the gear box oil? Is there gear box dipstick in the engine?
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
