Electrical Starting Fault?
alan589
Hello
I have a 40K 2006 D4D Yaris. just recently it has failed to start a few times. When I turn on the ignition there is nothing and occasionally one or two of the dash dash lights glow dimly.
Now..when this happened i had a look under the bonnet and fiddled with a few things. The problem is temporarily resolved by wiggling the poisitive terminal of the Battery.
It seems that there may be a loose connection of some kind. Has anyone else experienced this problem?
Kind regards
Alan
May have been left loose when it was last serviced? Tighten the battery terminals and it should be OK.
Cheers Reece
Will do!
Alan
