Engine Managment Light
jako999
Hi all I have had a few posts about this problem in the Rav section but comming up blank and as I'm sure they will all be the same, I thought I would post here. I have a UK 2002 Rav4 2.0 petrol the engine light came on and my code reader stated heater problem pre cat which was correct and replaced. I now get codes P0125, P1130 and P1150 has any one got any idea what could cause all these codes to come up it must be a common fault to them all. The only thing I can see is that one of the sensors levels out at a voltage of .46v and the other at .75v should they be the same? Both fluctuate with revs.
Thanks in advance :(
