hello
ive got a 05 aygo
and today i was in the boot and half of the matt in the boot was soaking on the left hand side
lifted the matt and found water to be on the plastic tray
Has anybody eles had these problems ? And do you know were the water comes from ? ( as the seal on the boot door seems fine )
thanks
hello
ive got a 05 aygo
thanks
Anybody ?????
hello
ive got a 05 aygo
thanks
if its not the boot seal there are two air vents behind the rear bumper that leak badly, also check the seals on the rear light clusters
they are known to leak lastly the high level brake light, it has a very poor foam seal that pours in water
hello
ive got a 05 aygo
thanks
Ive got an extended warranty will this be covered in it ?
thanks once again
hello
ive got a 05 aygo
thanks
thanks once again
as long as its reported to warranty as a failed parf then there shouldnt be a problem
Lmao...
