Found this item on eBayVisit My Website
I was wondering if any forum member has actually fitted one and could fitting it have any effect on the cars warranty?
bought one from citybugs (I think that was their name) and it works a treat and as to warranty no idea but my dealer actually fitted for us!! ;)
This will not affect warranty.
Fitting is easy: pull the light out of the trim, connect the red wire to the
red wire and the black wire to the white wire with a black strip. DONE!
and tie all with a zip...push them gently back in!
2 yrs and working fine, not affecting warranty...
I did this and it works a treat, I also added a philips blue bulb which give about 50% more light in the cabin.
Did this two years ago and I have had no issues with iy.
Good Luck
Fitted one of these today, gives you a good 15-20 seconds extra light.
Ι think you say too many. I 've timed mine and the least is 1-2secs the most 10secs.
Just been out defo 15 seconds
Anyone got a link for where to purchase?
Just been out with the stopwatch on my phone and from the time my door shuts till the time the light finally goes out is 14.38 seconds
hahahahahahahahaha
just wondering, does it trigger the "door open" light? for 14 seconds after closing all doors
hahahahahahahahaha
Precision at its best! :D
hahahahahahahahaha
I got 14.28. Im sure welshviking is a liar
hahahahahahahahaha
DOH !!! I want a refund, yours must be the Usain Bolt version.
Aygo's don't have a door-open light... The lights-on warning buzzer WILL sound!
On other cars it may deend on the way the light is connected to the switches.
Got round to fitting one today .All working fine. Have not timed it yet but seeing as everybody seems to measure to the microsecond will wait until i can get the official olympic game's timekeeper to verify the delay :D
Here we go Bitzer put us all to shame....no more arguments...GO FOR IT !!!!! :D :D
http://cgi.ebay.co.uk/LONGINES-OLYMPIC-STO...=item335806063d
Thanks for the link Welshviking.
Just fitted one myself and it works great.
Don't know if my wiring is different because I don't have a white wire with a black trace behind the light.
I ended up fitting it beside the door switch as per the supplied instructions, just below the seatbelt.
How long it stays on seems to vary and depend on how long the door is open for. If I open and shut the door quickly it lasts less than 10 seconds, but if I leave the door open for 10 secs or more it stays on for 15 to 20 secs.
All I need to do now is find out how to wire it into the central locking so the light comes on when I unlock the car :) (pointless I know, but it'll look cool!)
What you want is next to impossible with those cheap delay-thingies...
What wirecolors DID you have at the dome light?
...Yes, thought it might.
They were white, blue and red.
Just for info, the unit I fitted was designed to fit beside the door switch, the units red wire connected to the switch wire, and the black wire connected to earth.
The white wire is ground, red is from the switch (changed to pink somewhere at a junction), blue is positive.
Whether you connect the delay at the door or at the light doesn't matter, as the electrical connection is exactly the
same, I've allways installed them at the light since it doesn't involve removing trim at the B-pillar, so it saves time.
anybody having an issue with their delay??? Ours had started to dim and then not go fully out - dealer checked it today as part of our aygo's first service and say the delay unit is at fault?? Anyone........ :unsure:
Did you change the bulb to one that consumes less power?
Like an LED-bulb or something like that?
