Did you change the bulb to one that consumes less power?
Like an LED-bulb or something like that?
no standard bulb!
  • 6 years later...
Anyone fitted one not from city bug (they are out of stock and no date for stock?)
they are really easy to fit,there are different types you can get some have a 4 wire connection and some have just 2 wires
at the end of the day they will all keep your light on after the door is closed ,when using an led the light will
stay on for a little longer due to the lower power draw from the led.
Thanks, what one did you fit ?
i cant see the ones i have used in the past but i have found a link for one on eBay
http://www.ebay.co.uk/itm/Time-Delay-10-sec-Interior-Light-Dimmer-Brand-New-/371745507418?hash=item568dc2485a:g:9ikAAOxy-W9STE3o
simple to fit the red wire connects to the pin switch and the black wire goes to the car body
thats it jobs done.
Thanks, did you fit near the door pin or near the main light ?
when we had an aygo i fitted it to this car i connected it to the rear door switch so i could hide the
delay unit under the rear seat base i also used the seat back mounting for the earth connection.
