Rear Door Light
LA-LA
My new rear door interior light is linked with the A-pillar-"electric-lines", but you can fixe them to the domelight as well very easy.
The footlights are old Audi-part too.
To put the wires through the rubber tunnel (reardoor-rooftop) is more difficult. Use a "hard" cable!
Just pull it and start on the top. Only under the top part is a "holderthing"(you can see it true the opened cap) that needs to be turned 90degrees. I did it with my thin fingers otherwise use thin tool.
Pfff hard to explain in english. Maybe someone else better explains.
Anyway, just try it yourself. It's very easy to remove.
Good luck!
:help: Who can explain how to remove this part???
Pull it...
Pray...
Pull harder...
Close your eyes...
Take care not to get it right in the face or to scratch your interior... lol
Just go on toyota techdoc europe and find the alarm system installation guide... everything you need in it.
EDIT : http://techdoc.toyota-europe.com/legacy/To...M_001_497-1.pdf
Page 10...
