What Size Rear Speakers To Use On Yaris 2000 Model
CUTEUKM786
The standard head unit won't be putting out more than 20 watts per channel - so any quality aftermarket Speakers will do.
There's no benefit going up to higher wattage Speakers because its the power of the head unit that drives the output wattage and sound level... The "wattage" of a speaker is merely the maximum output it can take from a head unit or amplifier before it is damaged.
I don't wish to worry you but Speakers don't usually fail completely - especially both of them - its more likely to be a head unit or wiring problem....
Just a word of warning that its worth double checking before you go out and buy new speakers and then find the rear still doesn't work...
