Hi I understand that the two batteries on my surf are for winter starting and associated accessories.
As the surf is currently in Uganda this does not apply.
I see that the right hand ( looking from the front) Battery has the starter conected and the left has wiring connected to a fuse box, I would assume it would only be necessary to have one Battery on the right and connect the left hand wiring to this??
any info comments, helpwould be appreciated
Yes you could have only one Battery, but it would need to be a bigger one that was fitted, as they fit two to get a higher cranking amperage.
