Carina E Gs
i have a leaky boot , and I'm running out of Duck tape
HELP !!!
I'd seal up the top of the lamp units so that water can't run behind them using insulation tape or/and silicone sealant and rub vasoline along where the rubber seal joins the drain channel.
Don't jet wash around the boot!
It may be worth checking for rust or a poor repair around the wheel arches too.
HELP !!!
where do you find the water is it under the spare none of my carinas have ever had any leaks but recentley my quahter lte window was smashed and lots of ice nicked when i replaced the window even tho i was carful used the sealent stuff when i used jet wash or even garden hose the water was comin trough the window and colecting in the boot under the spare or it could be the boot seal a good idea would be to dry it out wipe it clear the boot then spay with hose while some one in side try to find where it is coming in then you will have problem that you know what to fix i have a manule every one should get a haynes manule
Try to smear some vaseline on the rubber plugs down under the spare wheel. I had problems with water under the spare wheel before and noticed that the rubber plugs were very dry and hard. After I put some vaseline on them there has not been any water under the spare wheel.
