Hi Now that i have my aygo the questions will start as i have no handbook to look at. Just trying to check the coolant level but cannot see any MIN / MAX marks, can anyone please tell me where to look on the reservoir for these marks......Just to add it has pink coolant in which i am guessing is the good old Toyota pre mixed long life coolant....Cheers Colin
Sorry for answering my own question here, i had a look with a torch and found the min/max levels on the back of the reservoir and the level is perfect, i also checked the water pump for any signs of coolant leakage and that again is perfect no sticky pink fluid escaping from where it should not be.....Colin
take a second look, cause dirt from road, HIDES pink colour...
scratch the pulley with your nail for sure!
Cheers Kav, 2nd look and as clean as a whistle, not any pink coolant in site (apart from inside the reservoir off course ;) )
ok, well done. make sure when your warranty expires, cause pump will 100% fail.
when ? from 10.000 - 80.000 km since bought new....
its teflon is not working properly, so do not go for the same part, when this happens, a new pump is released silently from T, which solves the problem.
hope i helped...
if out of warranty, get it now cause it's price rises every day.
