Paint Problems !
andydata
Hi guys,About a year ago we had a new offside wing replaced and sprayed.Now I find that the entire wing has started to produce little pin like bubbles all over the place like measles.Anybody know what has caused this and give advice.regards Andy r....
Could be caused by a lack of rust protection being done to it before painting. The microscopic holes in the paint bubble up because of the rust building on the panel.
Unless of course you have scratched it and the rust is because of that. Otherwise, it's just the panel didn't receive sufficient rust protection. :)
This problem can also be caused by a reaction between the top coat and the primer.... or.... the top coat was not properly mixed prior to being sprayed :blink:
Take the car back to the spray shop as the job should carry a guarantee :yes:
Good luck :thumbsup:
