Knocking =s
Vitz_man
Okay, here's the deal. Just stuck an old set of steel rims on the car with snow tyres cause of the bad weather. Up here in Aberdeen you need them! :P
I've made sure they're all fitted correctly and they're pumped up to the correct pressure, but there appears to be a knocking coming from one of the tyres at the front. (Repetative knock which increased with speed). Ironicly I believe it to be the same wheel that I struggled to replace. The knocking wasn't there before, so im assuming it has to be something to do with the wheels. Since im not planning on keeping them on the car for very long, am I safe to assume that its just the tyres or something and that im okay to drive with them? I'd rather not risk my TTE alloys on the kerbs given the weather conditions... :unsure:
Thanks all! :D
