Steering Wheel Height Adjustment
1304
Hi, I have a 02 Avensis and have found that if I drop the steering wheel to it's lowest position (For the wife to drive) there is a slight tight spot on the steering on the straight ahead position.But when I lift it to the top it's silky smooth all the way from lock to lock. Can this just be a joint that needs some grease, or should I just leave it in the up position.
Any ideas?
