Hints And Tips
GIDDLEPIN
I notice there isn't one under "Important Topics"
If you would like me to set one up from any "How to's" past or present, just PM me the link and it will be done :thumbsup:
Les
Les
Well sounds good to me, much needed and im sure would be of interest to other members,
Don't know if this is the right place to post this, but here goes...
How to reset your Auto electric window function.
If, like me, you let the wife use your beloved Auris to pop down to the post box when the weather's freezing and, if like my wife yours decides to wind the window down to clear the ice off (?????)... and, if like mine, your window is frozen solid and it stops the auto function working and causes the auto light on the switch to flash, here's the procedure to reprogramme the auto wind unit.
Simply turn the ignition on, wind the window all the way to the bottom and hold the switch down for at least ten seconds. Then wind it all the way back up again and hold the switch for another ten seconds and voila, the system's reset!
Sorry if this in the wrong place Les :(
It's the right idea bobbo and I have started things off but it is better to start a new post for each one and that lets other people add any comments :thumbsup:
