Nearside Colour Coded Wing Mirror Cover Needed
arunanb
The nearside wing mirror cover has disappeared (either nicked or fallen off)!
Can anyone suggest where the kind of cost that it will cost to replace this and possibly the cheapest place to get a colour coded (black) cover is from?
Additionally is it easy to install? i.e a simple case of snapping it into place.
Thanks....
when I was looking for mine the cost of cover was about £20 + painting another £20 from Toyota. Check eBay too. The paint code you can find on driver side door jamb. The plastic doesn't look damaged so you can simply clip it on.
There are people breaking Auris's on eBay so a bit of look you will find a car being broken the same colour then just email the seller to see if he has the mirror ;)
