Help.
I have developed a strange mist on the windscreen directly on the drivers side.
Its on the outside. I wipe it and it reappears. I wipe it again and it reappears exactly as it was. I poured hot water over it, I scrubbed it and tried everything.
It temporarily disappears for a second then its back. Like condensation or something.
What should I do? Anyone experience this?
Help.
Try removing it with warm water mixed with white vinegar and then dry with srunched up newspaper
Could it be an imperfection in the glass that is magnified by the condensation?
could possibly be grease? Try a proper window cleaner in it maybe
If you suspect it's oil or grease try using a strong mix of hot water and biological washing powdwer - the enzymes in the washing powder break down fats and oils.:)
