60,000m Service
Toylew
Looking at a 2003 Rav4 for my wife, 2.0 nrg petrol (she currently has a 1996 GS), and its due its 60k service, the second hand dealer seems reluctant to perform this, he said he would do a safety check (I'm assuming this means he will give it a quick glance and pump the tyres up a bit), any way is this a major service interval, I know it does not require a cam belt as its chain driven. I have googled this but cant seem to find any info, thanks in advance.
Managed to eventually find this, hopefully may be of some help to someone.
Inspect disc brake pads and rotors.
Inspect brake linings and drums.
Inspect
Ball Joints
Inspect brake hoses and lines.
Inspect Constant Velocity Joint Boots
Evaporative Emission Control Canister
Inspect exhaust pipes and mountings.
Inspect fuel lines, connections,fuel cap and gasket, fuel tank band (strap) and fuel tank vapor vent system hoses for corrosion, damage, cracks and loose or leaking connections.
Inspect steering gear box.
Inspect ball joints and dust covers, steering linkage and boots.
Inspect/Adjust
Drive Belts
Inspect for cracks, damage, excessive wear or oiliness. Adjust if necessary.
Inspect for excessive lifter noise and engine vibration and adjust if necessary.
Replace
Air Filter Element
Coolant
Engine Oil
Fluid - A/T
Fluid - Differential
Replace oil in front (if equipped) and rear differentials, including limited slip types.
Fluid - M/T
Fluid - Transfer Case
Oil Filter, Engine
Rotate Tires
Inspect
Ball Joints
Inspect/Adjust
Drive Belts
Replace
Air Filter Element
Coolant
Engine Oil
Fluid - A/T
Fluid - M/T
Oil Filter, Engine
Rotate Tires
From past experience, make sure the serpentine belt is changed, they do snap, my sister in laws 2002 model only has 54k on the clock, and it just snapped in North Yorkshire, make sure it is not perished looking or shiny and worn looking on top, if it is get it changed to be on the safe side.
Hope this helps, I have a diesel but my Haynes manual covers both models and suggests valve clearance check and adjustment for 60k service on a petrol model.
Plus everything you would have on 10k and 20k as required, which would include brake fluid change, fuel filter change, spark plugs (check and renew if necessary), cooling system flush and renewal, transmission lubricant renewal, pollen filter, air filter, oil filter and oil change.
Plus a whole list of other checks which if anything involves a quick 30 second visual glance over the pipes, exhaust, brakes and tyres and generally involves ticking a load of boxes unless something blindingly obvious strikes them while they're doing the other bits.
Of course they don't work straight off what a Haynes manual suggests and some garages will do less than others in terms of fluid renewal etc., best thing is to get a couple of quotes and ask them to list what is included at the very least the parts and fluids that are being changed and that the price includes them and the VAT, they wont really want to list all the checks, I haven't managed to get one dealer to do this in advance yet (although it really shouldn't be that difficult to copy and paste the same list they should be doing for everyone but of course then they can't pull the wool then can they?)
My 60k on the diesel was £400 ish but this included the timing belt renewal (very little else was done).
It should be worth a couple of hundred off the asking price though if this hasn't already been adjusted to take this into account.
I personally would only check the valve clearance if you can hear a problem as adjusting them is a very complex procedure for even the most skilled mechanic.
Excellent thanks a lot everyone, decided not to get it in the end. But have bought a 2002 2.0 nrg with a genuine 37.5k miles on the clock from a Subaru dealer who is happily servicing and moting it before we pick it up next week.
