Sat Nav Problems
bob123456
Hey I have an avensis car, and I have the CD to install the navigation sytem (TNS 310 TRAFFIC PLUS) but I do not have the manual for installing it. I need some help so I can get this thing working
I think this is actually how to put it in I want to actually install the maps with the navigation maps system TNS 310 PLUS.
http://www.toyota.com.cy/own/accessories/navigation.aspx
Look at this again and check the phrase download brochure at the bottom of the gray area, this shows you how to use it
It should automatically set up when you insert the CD into the unit under the passenger seat. You can adjust the settings with the Knob thingy on the dash but the cd should load up the maps automatically- unless the Cd is damaged
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
