What Engine Oil?
ItalianStig
So synthetics are your best bet.
Here's one for you then... What would be the best synthetic oil for a Yaris? I currently use Castrol Edge... I think, can't remember.
Which Yaris do you have? There's a bit of a difference between the oils, depending on year and engine.
Cheers
Tim
I would use a 5w-30 oil
http://www.opieoils.co.uk/c-653-5w-30.aspx
The best ones there are the Silkolene Pro S, Motul 300V and Redline, but the Motul X-Max, Gulf Formula FE and Fuchs XTR are good cheaper alternatives.
We also have service packs available here
http://www.opieoils.co.uk/c-341-car-service-packs.aspx
Cheers
Tim
I'll go with the Silkolene Pro S! £50 every 10,000 miles isn't so much when you think about. Better that than a new engine!
Any discounts for a Toyota Owners Club member? :D
How much oil does a 1 litre Yaris engine hold, does anyone know? I'm in the warm and my manual is in the car in the cold...
Don't be so lazy! :P ......................Go out.............Get the manual and read it! :P
I am sure that you will not loose any sleep tonight by not knowing :unsure:
3.5L
You are too kind :) ...........................Is that with or without the filter and is that the 4 cylinder or the new 3 cylinder?
I can buy a big 5 litre bottle of oil and still have some left for the next service. Brilliant! :D
