My father in law has a double cab hilux on a 53 plate. He had the timing belt changed last year, but now the light has come on to change the timing belt. Has anyone any idea on how to reset this light? Thanks in advance
Well it's all about sharing so I will share although no one bothered to reply. Its the same as the landcruiser where the dashboard has to be removed and the screw moved to the other hole to reset the cam belt light
chances are the reason no one replied bud, is no one new the answer :D
  • 4 weeks later...
IS THERE NOT A SMALL RUBBER BUNG ON THE DASH ,, YOU CAN REMOVE IT AND PRESS THE RESET BUTTON ON THE CLOCKS TO RESET TIMING BELT LIGHT ,,,???
And that doesn't work...Tried that already!
I'm also looking/searching how to kill that light....
