2007 Clutch Problems (noise)
darbyogill
i have a 2007 d4d t3 x avansis in the mornings when i start it there is noise comming from the car if i put my foot on the clutch it goes away also going from 1-2 gear is very tight this goes away the more u drive but the noise in da clutch dose not ...there is no slipping in the clutch and the peadel feels fine the car has done 110000 miles and has been serviced by main dealer from new
If it has only happened since it has been so cold 0 degrees or less, then wait till the temp. rises, as it could just be the temperature.
Marv
Marv
no its been there for a few weeks
check oil.
replace.
