Suspension
GreyRacer
381024631.jpgMy underneath is finally coming together.
Up till now I've fitted EBC dimpled and grooved disks with Red Stuff pads front and rear, Whiteline ARBs 24m front and 20mm rear, Eibach Pro-kit springs and a C-One upper engine bay strut, 215 tyres.
All that is left to do now is to fit my front wishbone polybushes and gear box linkage brass bushes.
The car is now stiff, really stiff. It corners flat and the lift off oversteer is now nearly eliminated. The Eibachs are a relevation. My previous two Corolla TS were on TTE but these Eibach are far superior. The 'progressive' nature of the springs is wonderfull. I can drive normally with very little reduction in comfort if any.
All I need now is some dry roads to push the limit although it will get a good workout at Knockhill soon.
