Rav 4 Diesel
haxbyville
hi all new member with problem.ive got 2005 rav 4 diesel,29k miles Since snow appeared late dec my light comes on in morning and goes off later in the day then some days on all the time ,other days not on at all ,only went into limp mode a couple of times.took it into garage today and fault code po627 is problem.Was not sure how to cure as he thinks i need new fuel pump but to make sure i dont waste too much money he has gone to fuse box in engine compartment and swopped over two fuses He says if it comes on again i need new pump if not i just need new fuse does this sound right as i have read on here so many reasons for the fault.Thanks for any help you may give
Welcome to the club.
You just need a pair of scv valves off kingo. Have a read in the maintenance tips at the top of the page.
thank you anchorman very grateful
have sorted with my garage and they are getting scv from kingo hope car will be sorted soon thanks
