Hello All,
It is time for brakes and I have a few questions.
Is there another application that will allow bigger brakes on the front? I have found no aftermarket solution (Brembo, Powerslot etc).
I am looking for some other vehicle application that should/ may work to replace the fron rotors and calipers.
NEXT...!
Since I have yet to be able to get the rear disc conversion for this car I guess I need to buy an entire rear axle, same question as above.
What car(s) rear disc axles will fit on the 92 Paseo?
Cheers!
Hello mate i'm a new member, Have you tryed a toyota corolla estate for bigger fronts? Check out www.jbmotorsport.co.uk and look under toyota performance parts they are selling a rear disc conversion. :)
If I remember correctly, the Starlet rear discs work on the 'seo. and Brembo does make front rotors. So does Powerslot. check eBay.
and for bigger brakes check out vectoredvelocity.com (sp?). they have a big brake kit, but you have to have at least 15" rims to fit them
