Need Help With 1990 Toyota Camry (won't Start)
ejmaue
I was driving home and all of a sudden my car got really weak and started running very rough. By the time I pulled over it died and would never really start again. The timing belt is new and timing is good. The fuel pump is working, fuel filter is okay. The plugs are sparking blue. I bypassed the air intake and that didn't help so the problem doesn't seem to be there. I tried spraying ether into the fuel injector but it didn't make a difference. When I turn the ignition the car turns over and sounds perfectly normal. After a couple cranks it attemps to start but only manages to shudder and then quit. After turning over and trying to start for a bit it seems to backfire back into the injector and out the air intake and then the cycle starts over again. To me the problem seems to be in the fuel injector somewhere. The fuel is making it that far but must not be getting through because there is a good spark waiting for it. I don't know where to go from here though.
Hi and welcome to the club :thumbsup:
Do you smell petrol when it is turning over?
If not you have a possible fuelling problem, if you do it could be a timing/ignition fault, but to be honest a professional diagnosis would be best. ;)
Les
Les
I don't smell petrol. Since It isn't igniting I guess I should be smelling it. I'm considering taking it in but not sure if it is worth the money. The car is near it's end anyway. Thanks
