Camry - Not Starting/slow To Turn Over?
Ok,have a `92 2.2 Gli Camry and now on the turn of the key,it`s very slow to turn over and not starting.
1st i thought is was the Battery,but i`ve tried a different one in mine (not starting still) and tried mine in another camry (starts fine).
Tried rocking the car in gear incase the stater motor was partually siezed but silll no joy.
Any ideas in where i should be looking for the fault now?
Thanks.
Starter could be worn, spark plugs might need replacing, air filter could be dirty, fuel filter might be clogged.
1st i thought is was the battery,but i`ve tried a different one in mine (not starting still) and tried mine in another camry (starts fine).
Thanks.
hi mate
have starter serviced first to be sure that chain link is removed. then check with sparks -- i deem they are faulty (???)
i had similar issue with Battery B4 and those was connected with issue with link between (+) and lead package inside --- but the density of the acid was in limits showing blue status circle indicator on the lid. Cheers/Igor
