Toyota Part Numbers.
OldRaver
Is there a way that I can tell if the replacement parts used by a non Toyota garage were genuine Toyota parts?
My Rav had the DMF replaced in August last year before I bought it. The part used and their numbers are listed on the invoice for the work.
They are as follows: Flywheel assembly T13450-27022
Clutch kit T04130-YZZJG
Bolt T90105-10045
I'm rather hoping that the 'T' prefix on these numbers denote them as genuine Toyota parts.
Is there a resource for me to look these up?
Many thanks.
Flywheel assembly number is correct: LINK
Looks like the clutch is non-OEM. Genuine parts never start with 0, and does not contain letters.
I couldn't find any reference to the bolt, but the number looks like an OEM.
They all look like Toyota numbers to me - even the clutch.
The clutch IS a Toyota part number, it's from the OPTIFIT range of cheaper parts for older cars. The clutches are re-manufactured
Kingo :thumbsup:
Thanks again for your replies.
St Thicket - I found the bolt listed further down the page you sent me - thanks!
Anchorman - I'm relieved to hear they are all Toyota parts :)
Parts-King - thanks for your reply, should I be concerned about having a re-manufactured clutch or is this fairly common practice?
