Where Can I Ground At Front Of Car
dandaman
Hi, i amp going to be installing an amp and some 6x9's in my 05 yaris on saturday. I am going to put the amp unter the front passenger seat. where can i attach the ground cable to thats within 1metre ayway from it?
Thanks for your help in advance
I'd lift up the centre console and see if there's a nice easy bolt to use under there you can make use of. (one screw in the rear cup holder and the front just unclips..)
Failing that, if it were me, I'd use one of the seat mounting bolts, making sure it was properly tightened back up afterwards....
Thanks for the quick response... I shall try that out tomorrow.
