How To Disable Abs Warnig Light
Juandan
15 hours ago, moh4 said:
Hi people, I have abs,parking break,and trackion control lights coming up on my avensis 59 reg plate. It's just coming up randomly sometimes.Also my dashboard shown check VSC system. Any idea?
This is totally different from the subject matter and I have been guilty of this too. It would be better to start a new topic, but since I am here, will give some suggestions.
You need to see if any codes have been stored! This requires a scanner that deals with ABS VSC. Does the 'check VSC' come on shortly after starting? This means ECU mismatch or steering angle sensor not calibrated. I usually restart the car to clear the fault, and later delete the code (C1288).
