Heater Fan Has Stopped Working. Any Ideas?
rickjhns
Hi, the fan in my heater (2004, 1.8VVTi) has stopped working, therefore I have no heating or ventilation. I have checked the fuse and this has not blown.
Does anyone know if this is likely to need a new fan, or is there a common fault which can be repaired? If it needs replacing, does anyone have any idea of the price for supplying and fitting.
Many thanks
Rick
Many thanks
Rick
Hi i had this problem during the summer my local garage checked and found the fan motor had gone they replaced with a recon fan motor cost £60 fitted i believe these motors can be repaired
HIMate,
My had a to much water gone thru it and the "bearing" was without grease.They have dissassmebled it and greased well and it is working fine.Coste me 20 pounds.
Rgds
Wojciech
