I have a Will Vi which is Yaris based and has round door mirrors which are not adjustable from inside the car.
I quite like the look of the Aygo mirrors as a substitute. Would some kind soul have a look at:
...and see if there is any similarity in the mounting plate or studs on an Aygo please?
Does the Aygo have an electric mirror option by any chance?
Not in the UK I believe...
No electric mirrors anywhere in the world on our cars...
And I don't think you'll get them to fit, at least not as easy as you'd want:
As you can see, the shape of the base-plate is quite different, but so is the size....
The rihgt-most edge of the plate is ±280mm, distance between the holes (not studs) on
that edge is ±115mm, then about 87mm from bottom-right to the lower one on the left.
Left to top is hard to measure, because of the adjuster, but should be ±175mm.
There's also a small hook near the top hole and a hollow
stud to align everything between the holes at the bottom.
And no, I didn't just take a mirror off of my car; I have an extra set for
a project I'm working on (and have been on-and-off for the past year)...
Many thanks for the information!
