Tiger Seal.
JappyBeast
Just won these rear spats on eBay,
http://i.ebayimg.com/11/!BlBznS!...wCcCGQ~~_35.JPG
http://i.ebayimg.com/22/!BlCr9E!CG...fM7tnQ~~_12.JPG
After Googling on fitting these, a few owners have used Tiger Seal to fit them and not !Removed! then in at all. They even claim that you cant remove them after it has set.
Has anyone used Tiger Seal before?
Is it that strong?
Who sells it?
Cheers!!!
I have never used the product but it seems that it does the job :)
CLICKY
yep it is damn strong. just make sure the sub surface is clean and secure.
Tigerseal (definitely strong stuff) will definitely hold the maudflaps but if you catch one on a kerb or such expect paintwork damage at least. Many mudflaps either use clips or screws through the rubber flap and should the flap become trapped then at worst only the flap is damaged or lost.:)
Its amazing stuff. Ive glued whole cars together with it.
Its flexible too, so fiberglass stuff is less likely to crack with the bodywork flexing.
http://i.ebayimg.com/11/!BlBznS!&a...wCcCGQ~~_35.JPG
Is it that strong?
Who sells it?
Cheers!!!
