Amazon Fuel Tank Problem
nsnadia
Hello all! I own a 06 reg landcruiser Amazon and am very happy with it, however i have noticed a problem i have with the fuel tank and would like to know if anyone else has experienced it or has a solution! Basically when i go to fuel up if i press the pump for faster fueling the diesel seems to backfire out of the tank and spill back out of the nozzle. So i have to fuel up slowly! It is almost as if there is some thing blocking it and it can only handly a slow realese of diesel in to the tank! Does anyone know what the problem might be? Thanks
It souynds like the breather has become blocked, trapped or disconnected. It a pipe which sits within the fuel filler, and lets the air out as the fuel goes in.
Hello all! I own a 06 reg landcruiser amazon and am very happy with it, however i have noticed a problem i have with the fuel tank and would like to know if anyone else has experienced it or has a solution! Basically when i go to fuel up if i press the pump for faster fueling the diesel seems to backfire out of the tank and spill back out of the nozzle. So i have to fuel up slowly! It is almost as if there is some thing blocking it and it can only handly a slow realese of diesel in to the tank! Does anyone know what the problem might be? Thanks
hello mate
yes it look slike the tank breathing pipe issue.
check it first.
Good luck/Igor
:unsure: Thank you both for the help!! will get it checked and post what happened! hope its not too expensive! :unsure:
no no no -- it must cost nothing ---just investigate the tank and tubes arrangement carefully :)
Good Luck/Igor
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
