what types of bulbs do i need to change the heater modual, cd player and speedo to green from orange?
any one have a brief description how to do it aswell?
The HVAC-panel uses two T5 bulbs, you need flattop or concave
LED-replacements if you want an even spread light in the panel.
The speedo uses 3 PLCC2 SMD LEDs, revcounter 2.
Replacing them involves taking the entire thing apart.
The radio uses 44 SMD LEDs size 1206, involves
taking the entire front faceplate apart.
I have a bit of experience with these modifications, but still it takes me
about 3 hours to do a radio and little under 2 for a speedo and revcounter.
You need to be pretty handy at soldering and some specialist tools are
a definate plus to have (a desoldering pistol or lead-sucker) as you
need to desolder 47 contacts on the radio display and 26 for the speedo.
If you don;t get all the tin/lead out you'll end up with a broken display
end you really need to take ESD into account too: I allways ground myself
with a special bracelet and don't touch anything I don't need to touch.
There should be a topic on here (in which I did a
translation fron Danish), but I can't find it right now...
And here's the topic I meant about chaniging the dash illumination:
http://toyotaownersclub.com/forums/index.php?showtopic=84302
The radio isn't described anywhere, I had a spare radio
that I just took a gamble on. Luckily that turned out fine...
